CTR cam?
Old Mar 8, 2004 | 03:44 PM
Carnage24's Avatar
Default CTR cam?
I was just wondering if i could run a CTR intake cam with a GS-R exhaust cam togther? Would this set-up give me a problem? Thank you for all your input on this subject.
Old Mar 8, 2004 | 04:03 PM
VsR785's Avatar
Default Re: CTR cam? (Carnage24)
dont think so, i think u should be alright without it, but of course u should get the other cam in the future...i know a friend that ran it like that and had no problems
Old Mar 8, 2004 | 04:54 PM
DocIowa's Avatar
There is no problem what-so-ever with running those cams together. You won't see much of a gain, maybe 5-8 hp.
Mixing and matching intake and exhaust cams can get you very nice results, if you know what you are doing. Some people do it to reduce overall duration on cam lobes, which makes for better idle and street-ability.
Old Mar 8, 2004 | 05:53 PM
Kendall's Avatar
Default Re: (DocIowa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DocIowa &raquo;</TD></TR><TR><TD CLASS="quote">Mixing and matching intake and exhaust cams can get you very nice results, if you know what you are doing. Some people do it to reduce overall duration on cam lobes, which makes for better idle and street-ability. </TD></TR></TABLE>
But being that the GSR exhaust cam and CTR exhaust cam are nearly identical, the setup is basically a "poor man's method" of upgrading cams.
Old Mar 8, 2004 | 06:19 PM
xx dc2teg xx's Avatar
Default Re: (Grizzly Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grizzly Adams &raquo;</TD></TR><TR><TD CLASS="quote">
But being that the GSR exhaust cam and CTR exhaust cam are nearly identical, the setup is basically a "poor man's method" of upgrading cams.</TD></TR></TABLE>
if they are nearly identical-wouldnt one believe that there is no point in upgrading the exhaust cam and only the intake.
Old Mar 8, 2004 | 06:26 PM
DocIowa's Avatar
Where are you getting that information?
The CTR and GSR exhaust cams are VASTLY different.
GSR exhaust cam:
EXHAUST lift - 9.4mm, duration - 227@1mm
CTR exhaust cam:
EXHAUST lift - 10.5mm, duration 235 @1mm
How are they even close? Almost a full mm more lift, and more duration as well. A full mm difference is HUGE in cam specs.
I spent 3 months trying to decide if I wanted a 12.1 or 12.5 lift, and that's only .4mm difference!
But I was wrong on my estimation of hp. Installing both CTR cams will give you max, 10 hp on a GSR. So, in my opinion- it's a waste of $$, unless you get them REALLY cheap.
Old Mar 8, 2004 | 06:58 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DocIowa &raquo;</TD></TR><TR><TD CLASS="quote">Where are you getting that information?</TD></TR></TABLE>
I'll have to look into it. I've seen a lot of cam specs for what various people claim to be different cams, but end up performing similarly. I had a friend who dyno'd his car with a CTR intake cam a few times with the CTR exhaust cam and a few times with the GSR exhaust cam. I think he made .2 more horsepower up top with a maximum gain of .4 horsepower with the CTR exhaust cam when compared to the GSR exhaust cam. The engine was running with I/H/E, a skunk2 manifold and a skunk2 ECU.
Maybe I'm dead wrong, I don't know.
Old Mar 8, 2004 | 07:25 PM
Maybe I'm dead wrong, I don't know.</TD></TR></TABLE>
specs wise they are totally different like stated above, as for the dyno maybe gains are minimal when you only swap in the exhaust cam and not the intake
StupidSlowRSX
Aug 1, 2011 05:25 PM
isumase
10
Jan 27, 2008 02:09 AM
Diyracing2
Dec 21, 2006 07:41 AM
westdoor
Apr 9, 2003 10:26 PM
2k1 GSR
Nov 27, 2002 10:35 AM
