cranking problem!!
Old Sep 25, 2004 | 10:29 PM
kwoksturr's Avatar
Default cranking problem!!
I have a 94 Integra LS automatic and every now and then, the car just wont crank. The battery, starter and alternator are all good. This has happened twice already, and both times I have to leave the car alone for TWO HOURS before it could crank again. I even took my car to the shop and all they said was "Well the car is running now so you shouldnt have any problems." yeah like that was helpfull.. but if anybody has any ideas on what the problem could be then feel free to leave comments....
Old Sep 26, 2004 | 05:10 AM
gsrboi80's Avatar
Default Re: cranking problem!! (kwoksturr)
check your cables might not be getting good ground or somthing
Old Sep 27, 2004 | 04:56 AM
JimBlake's Avatar
Next time it happens, you'll have 2 hours to get your multi-meter so you can look for the flaky connection.
Check whether you get battery voltage at the starter signal wire when you turn the key to 'start'.
Check whether you have any substantial voltage drop across ANY of the big cables. Battery (+) & (-) along with the big engine/body ground.
Hit the starter with a broom handle or something.
If you can't figure it out from there, post back with the results of each of these checks.
Old Sep 27, 2004 | 05:20 AM
JUN1OR's Avatar
Default Re: cranking problem!! (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
Funny, but true, I had a dead spot in my starter on my 94 gsr. Had to be replaced, but yes, JimBlake is right, get out the tester. If you don't own one, go buy one. It's like a mans best friend.
Junior
BistaYang
Jan 28, 2013 07:35 AM
Inextricabledrvr
Dec 18, 2008 04:33 AM
incognito E46
May 30, 2005 05:06 PM
kaoss_11
Aug 28, 2004 04:36 PM
CivicBoi
11
May 27, 2002 11:30 AM
