crank help
Old May 14, 2002 | 11:38 PM
baonest's Avatar
Default crank help
http://www.imagestation.com/picture/...5.jpg.orig.jpg (not even gonna try to post it) i got all the internals out except crank.. do i need to take the 2 plate looking things out on each side of the block.. one that is shown in this pic and the other one that is where the clutch is... or does the crank just slide right on up (or down) and also should i put the screws back in where the plates are??
[Modified by baonest, 3:39 AM 5/15/2002]
Old May 15, 2002 | 05:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: crank help (baonest)
Not sure what plates you refer to.
Old May 15, 2002 | 05:54 AM
baonest's Avatar
Default Re: crank help (PatrickGSR94)
the thing sticking out where u put the crank pulley is on some kinda plate thing, i took the bolts off of it, also on the other side is another plate looking thing... i just wanna know if the crank lifts right out without and "twisting or turning"
thanx
jackstands
Mar 13, 2005 08:54 AM
NightHawkC5
Mar 4, 2003 09:48 AM
