could this be the distributor?
Old Mar 19, 2008 | 03:34 PM
MrKrizzle's Avatar
Default could this be the distributor?
so whenever i start my car, it runs really rough until it warms up after a few minutes. i have to gas it during this time or else the RPMS will drop too 100 and almost die. Once its warmed up it runs okay 40% of the time. The other 60% of the time at a stoplight the idle will drop to like 400 or lower at times. I have changed my sparkplugs, wires, cap & rotors. I tested my battery and alternator and get perfect voltage readings. I also cleaned my IACV+throttle body. So is this my distributor causing this? any help is appreciated
Old Mar 19, 2008 | 04:12 PM
r3vmixman's Avatar
Default Re: could this be the distributor? (MrKrizzle)
Possibly running to lean. Check your fuel filter, fuel pump first if its not that check injectors for clogs.
Old Mar 19, 2008 | 07:59 PM
MrKrizzle's Avatar
Default Re: could this be the distributor? (r3vmixman)
my injectors are fine, and my fuel filter and pump are fairly new so i doubt its. anyone have any other ideas. its not throwing a CEL either
Motita
Nov 30, 2010 10:37 AM
97CWITR
Sep 23, 2009 05:38 PM
armygsrcivic
Jun 6, 2006 04:00 PM
B18CRacer
Feb 14, 2002 01:36 AM
