correct coil over setup
Old May 8, 2006 | 02:54 PM
legends's Avatar
Default correct coil over setup
Im planning on buying tein basic coilovers for my 00 gsr. I know i need to do something about camber. Do i just need a camber kit? Do i need it for the front and rear? can u run camber kit front and lca in rear?
Old May 8, 2006 | 02:56 PM
.brian.'s Avatar
Default Re: correct coil over setup (legends)
if you are just lowering 1.5-1.75 inches, you should not need a camber kit. any more than that, i would get on for the front. you can do "the washer trick" on the back, but you should be ok on the back, unless you are really slammed.
also, you may want to put some money aside in case you cannot get your rear lca bolts out. you may need to buy some new rear lca's.
don't forget to get an alignment a few days after you put the suspension on!
Old May 8, 2006 | 02:59 PM
legends's Avatar
Default Re: correct coil over setup (.brian.)
thanks. so what exactly does a camber kit do? allow you to adjust camber in a different range?
Old May 8, 2006 | 03:50 PM
legends's Avatar
anyone else got some input?
Old May 8, 2006 | 04:10 PM
magicaltrout's Avatar
get a camber kit. you can't go wrong with having better tread wear and a full contact patch between the tires and the ground. make sure you do an alignment after everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">also, you may want to put some money aside in case you cannot get your rear lca bolts out. you may need to buy some new rear lca's.</TD></TR></TABLE>
Old May 8, 2006 | 04:17 PM
legends's Avatar
Default Re: correct coil over setup (magicaltrout)
which lcas would you recommend?
Old May 8, 2006 | 04:26 PM
if you're on a budget and you have the right tools you might want to try
http://www.team-integra.net/se...=1025
all it would cost you is a set of lower shock mount bushings, less than $30, and a saw blade, less than $5. i went with this method when my install turned awry.
if you want new LCAs, i hear a lot of good about Omni Power.
http://www.omnipowerusa.com/Pr...s.asp
I don't have first hand experience with them so I guess you can try searching the forum or wait until someone that has them sees your thread.
Old May 8, 2006 | 06:03 PM
dannylDAsport's Avatar
what kinda driving??? daily??? autocross??? track?? daily drive get camber kits save you tires. autocrossing dont get, negitive camber better for turning. track get camber kit more tire contact.
Old May 8, 2006 | 07:35 PM
legends's Avatar
Default Re: correct coil over setup (dannylDAsport)
Its a daily driver. Dont want to lower it too much but a noticeable amount. So can anyone tell what a camber kit actually does?
Old May 9, 2006 | 09:49 AM
when you lower your car too much your tires get angled like this:
/-----\ (when you look directly at it from the front or back)
camber kits allow you to set it back to normal like so:
so your tires don't ride on its side...
sort of like standing on your toes so to speak.
Old May 9, 2006 | 11:34 PM
sLaMmEdC2's Avatar
get custom ground control .... go low or go home
Old May 10, 2006 | 05:51 AM
tvman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magicaltrout &raquo;</TD></TR><TR><TD CLASS="quote">when you lower your car too much your tires get angled like this:
sort of like standing on your toes so to speak.</TD></TR></TABLE>
hahaha...i thought that was koo...but yeah...you should get an alignment...i got mine at firestone...i dont know if they still ahve the deal but i paid $120 lifetime and i can go whenever i want to as long as i own my car
Old May 10, 2006 | 06:40 PM
legends's Avatar
I know that. but what im asking is the camber you would want to adjust it to too far out? Why couldnt i adjust the camber the way it would be with just coilovers?
njl481
Suspension & Brakes
Feb 24, 2012 12:11 PM
redDAinteg
Apr 29, 2008 06:30 AM
hondaPINK
Suspension & Brakes
Oct 24, 2006 02:45 PM
es_squared
Apr 3, 2004 02:04 AM
Takeoff
Aug 11, 2002 01:08 PM
