corner lights
Old Feb 4, 2003 | 02:51 PM
bgx9ner's Avatar
Default corner lights
i got a 93 teg and want to install clear corners. i took off the screw and still it wouldn't come out. how many screws are there? is there pics somewhere i can look at to see exacly how to take them out? also i noticed that the parking and corner blinkers don't work? what should i check for? i checked the fuses-looked ok- but i will do it again. they were working a little while ago
Old Feb 4, 2003 | 05:42 PM
Adachi's Avatar
Default Re: corner lights (bgx9ner)
The corner lights only have 1 screw, they're probably just in there really tight. Push them forward from the side lense (if that makes sense). Dunno about why they aren't working though.. check he bulbs.
Old Feb 4, 2003 | 06:12 PM
90RioGS's Avatar
Sometimes those corner lenses are really stuck in there.. i ended up snapping one of my tabs gettin them off once.. But they will come out! just keep pullin and be careful
Are none of the blinkers working? or just one or two?
Old Feb 5, 2003 | 10:50 AM
bgx9ner's Avatar
Default Re: corner lights (90RioGS)
just the corner ones. the front and rear works. i think it could be from when i took out the screws. i think thats the ground. i haven't placed them back yet, cause ever day i'm tugging at the mother. and still, they won't come out
Old Feb 5, 2003 | 04:06 PM
Adachi's Avatar
Hmm, that screw isn't the ground, the ground is a wire going to the bulb.. so it's either a blown bulb or faulty wiring.
Old Feb 5, 2003 | 05:39 PM
Full Race EG's Avatar
Default Re: corner lights (Adachi)
1 screw. Angle the and slide them out. If stuck, beat on them a bit
Fo-Do Fanatic
16
Jul 19, 2009 05:40 PM
Ghost Shadow
Dec 27, 2007 08:27 AM
accordmaniac23
Feb 10, 2007 05:05 PM
AmericanNightmare
Oct 26, 2002 10:30 AM
