Coolant Temp Sensor
Old Oct 21, 2003 | 05:39 PM
Rival23's Avatar
Default Coolant Temp Sensor
Does anyone have a picture or even a description of where the coolant temp sensor is, i am getting a CEL code 6, so i want to try replacing the sensor but i dont know which one it is
Old Oct 21, 2003 | 05:41 PM
kev301's Avatar
Default Re: Coolant Temp Sensor (Rival23)
if i'm correct is on your themostat housing.
Old Oct 22, 2003 | 07:14 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If you follow the lower radiator hose to where it connect to the engine, look for a wiring harness that plugs in right next to that. That is the sensor.
Old Oct 22, 2003 | 08:24 AM
IN VTEC's Avatar
Default Re: Coolant Temp Sensor (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">If you follow the lower radiator hose to where it connect to the engine, look for a wiring harness that plugs in right next to that. That is the sensor. </TD></TR></TABLE>
That's the fan thermoswitch. The ECT sensor is on the side of the head, behind the upper radiator hose housing on PR4/P75/P72 heads and in front of the upper radiator hose housing on PR3 heads.
I think the sensor is 2-wire and has a green plug.
Old Oct 22, 2003 | 08:48 AM
JimBlake's Avatar
Default Re: Coolant Temp Sensor (IN VTEC)
Yes, the one in the T-stat housing is the fan switch.
There's 2 sensors at my upper radiator hose. The 1-wire sensor is for the dashboard gauge. The 2-wire sensor is for the ECU.
DisplacedMic
Jul 27, 2016 12:33 PM
Billy Baird
Dec 27, 2012 10:32 AM
4CDFED
11
Aug 9, 2006 06:03 PM
2000_Civic_Si
Apr 3, 2002 09:03 AM
