Coolant flush question
Old May 11, 2017 | 07:09 AM
91akira's Avatar
Default Coolant flush question
Using a garden hose to into the Radiator, will it flush out coolant from the Heater core as well?
Old May 11, 2017 | 08:29 AM
MotorMouth93's Avatar
10 Year Member
Default Re: Coolant flush question
If you set the temperature slider all the way on hot then yes it should. But I'd just disconnect the heater core hoses and flush it on it's own too, that way you can flush it backwards and forwards to clean it out better.
Old May 11, 2017 | 08:39 AM
91akira's Avatar
Originally Posted by MotorMouth93
If you set the temperature slider all the way on hot then yes it should..
"Set the slider all the way on hot"? Is this with the engine on idle or not on idle?
Old May 11, 2017 | 10:24 AM
NVturbo's Avatar
O.G. triple O.G.
if you want to completely remove all the coolant, loosen and remove the drain bolt behind the header. That will drain all the coolant inside the block as well.
Old May 11, 2017 | 11:40 AM
10 Year Member
The slider is connected to a cable that's connected to a valve sticking out of the firewall. When this valve is open coolant can flow into the heater core.
Just go look at the coolant flush instructions in the service manual. That will explain it better than I can.
MrViet
Oct 20, 2009 09:43 PM
hondachris1994
Mar 21, 2006 11:13 PM
turbotime
78
Aug 3, 2005 05:09 PM
eL
Sep 23, 2004 06:25 PM
stRtypR25
Jan 18, 2003 04:49 AM
