Compression testing (I need advice) repost
Old Aug 18, 2001 | 09:26 AM
wantmorepower's Avatar
New User
Default Compression testing (I need advice) repost
I was doing compression test on my b18c1 engine w/ 10k miles and I got the following numbers:
1 2 3 4
210psi 200 200 220----I got 220 after the third attempt, the first two times I got 135psi and when I put a teaspoon of oil in the cylinder I got 220 and then 235psi ----IS THIS NORMAL? Please reply. Thanks (I was not pressing the gas...)
Old Aug 18, 2001 | 10:28 AM
ingrate's Avatar
25 Year Member
Default Re: Compression testing (I need advice) repost (wantmorepower)
try keeping the throttle fully open next time.. and how many times did you crank the engine? You also might wanna disable your fuel injectors by either pulling the wire harnesses by the distributor or pulling the ecu fuse if you haven't done that already. 135 seems kinda low...
Old Aug 18, 2001 | 11:06 AM
MintyDip's Avatar
Default Re: Compression testing (In7egrity)
try going to http://www.c-speedracing.com they have an awesome how to section. They have a how to do a compression test with full description...hope that helps
I think u have to hold the gas,if I remember coerrectly...check the site
Old Aug 18, 2001 | 12:06 PM
Ri5e's Avatar
Default Re: Compression testing (MintyDip)
You MUST keep the throttle wide open. Push down on the accelerator all the way or get something to keep that throttle open.
Ender Ho
Dec 24, 2014 07:15 PM
umair
Dec 7, 2009 10:37 AM
gs-R_swap
Oct 4, 2009 12:12 PM
gtec8285
Jun 24, 2008 01:18 AM
wantmorepower
Aug 17, 2001 02:55 PM
