Compression Test Results.
I just did a compression test and the results were 193 179 193 200. The numbers vary quite a bit but I was wondering if I would be safe from any problems by using the car as a daily driver (meaning that the car will be stock). The variance between the first and second cylinder is 14PSI, which is acceptable but between cylinder two and four is a variance of 21. Is this anything to worry about?
The numbers for your 2nd cyl might be a little low, but do you really want to rebuild your motor because its a little low? In other words you should be fine if its just going to be your stock daily driver.
I would adjust the valve clearances and redo the test. You can also add a small amount of oil (~1 tsp) to the suspect cylinder to check the rings for blow-by.
I'm guessing that it's the rings but I'm not really disturbed since this is my daily. I was wondering though, is reliability sacrificed with worn rings? The number in cylinder number 2 isn't too much lower than the others and quite frankly, if the car just burns oil I'm willing to live with it, as long as the reliability is still there.
I think that you're right. You guys all know what I'm talking about at least. Thanks for the info
. Btw, are these numbers ok to boost with?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockDC2 »</TD></TR><TR><TD CLASS="quote">I think that you're right. You guys all know what I'm talking about at least. Thanks for the info
. Btw, are these numbers ok to boost with?</TD></TR></TABLE>
haha, you were talking about "stock" and "daily driving" and now your talking about boosting. Sure the numbers are fine for low boost on a decent size turbo and tune. But you can expect a rebuild sooner than anticipated if you do boost the engine in that condition.
. Btw, are these numbers ok to boost with?</TD></TR></TABLE>haha, you were talking about "stock" and "daily driving" and now your talking about boosting. Sure the numbers are fine for low boost on a decent size turbo and tune. But you can expect a rebuild sooner than anticipated if you do boost the engine in that condition.
trecool44
Jun 19, 2007 06:52 AM
Chubz
Jun 27, 2002 02:00 PM
. Plus, you never know, later in the future I might want to give the car some kick.
