Compression test results
Old Feb 24, 2006 | 05:52 PM
CivicSiDriver02's Avatar
Default Compression test results
My compression came up as 189-182-172-169. Also why do you have to have the engine at full throttle when you do the test? I did the test twice and got the same results with and without the throttle open. Anyways are these good numbers? I know they are with in spec but im just curious what people normally get. BTW this is on an ls motor.
Old Feb 24, 2006 | 06:18 PM
yee SERIOUS's Avatar
that's not definitely the best. the motor has been worn as you can see. i've come to see that usually the 3rd is a bit lower than the others because it gets the hottest.
my comp test on my gsr was 235 straight across 1psi difference on one or two.
my comp test on my ls ek was 200 straight across.
both motors are 2000 model
Old Feb 24, 2006 | 06:25 PM
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">that's not definitely the best. the motor has been worn as you can see. i've come to see that usually the 3rd is a bit lower than the others because it gets the hottest.
both motors are 2000 model</TD></TR></TABLE>
Think I should just go ahead and do a motor swap? It will just be an jdm ls. Also why does the throttle have to be held open while performing the test?
Old Feb 24, 2006 | 06:33 PM
just do a lsvtec for fun. lol u can do a jdm ls if u want less hassle though. just move things from your current motor over the the jdm one. you'll have to interchange some things like fuel rail, distributor, etc.
i don't know why you gotta hold it down at WOT. maybe to increase pressure?
t-town_ep
Feb 6, 2012 09:24 PM
jdmcivic2fast
Oct 2, 2011 08:19 PM
berettagtz117
Mar 6, 2007 04:09 PM
Got_soy
28
Aug 8, 2005 12:49 PM
gsr~hatch
Apr 17, 2003 03:19 PM
