compression test numbers...
Old Apr 14, 2003 | 09:57 AM
allmotorls95's Avatar
Default compression test numbers...
i did a compression test on my friends ls and these are the numbers...150, 150, 140, 30... do you think we could have a blown headgasket..??
Old Apr 14, 2003 | 10:45 AM
Default Re: compression test numbers... (allmotorls95)
can anybody help with this or is forum completly useless..
Old Apr 14, 2003 | 11:15 AM
VTEC-DA's Avatar
Probably not a blown headgasket. How many miles on the motor? Does it blow smoke at all? Does it use alot of oil?
Old Apr 14, 2003 | 12:14 PM
Default Re: compression test numbers... (VTEC-DA)
it does go through oil alot but no visible leaks from the headgasket area...could it be the ring on that cylinder?
Old Apr 14, 2003 | 04:21 PM
bump?
Old Apr 14, 2003 | 04:55 PM
E-Rok's Avatar
EPIC TUNING
how many miles? and is that 30psi or 130?
Old Apr 14, 2003 | 05:23 PM
neo1z's Avatar
Default Re: compression test numbers... (rewsnaeht)
That is 30...wow. Youre running on 3 cylinders practically...perhaps you blew the ring on that cylinder.
Old Apr 15, 2003 | 08:56 AM
Default Re: compression test numbers... (neo1z)
it is 30....i have no idea if its the head gasket or a ring...anyways i guess ill tell my friend its time for a rebuild..
Old Apr 15, 2003 | 09:32 AM
VTEC-DA's Avatar
Oh, I didnt even see that 30, I read it too fast and thought it was 130. Your rings are probably shot in that cylinder. Either that or the headgasket is blown on the side. Either way, its time for a rebuild.
mynameizstitch
20
Feb 14, 2010 09:55 AM
zc89hatch
13
Dec 21, 2008 11:40 AM
RudeBwaiSi
Feb 23, 2006 01:07 PM
aracer69
Nov 16, 2003 06:14 PM
98civicEX
Apr 8, 2003 10:55 AM
