Is this compression test any good?
Old May 2, 2008 | 08:35 PM
Scrapin4DR's Avatar
Default Is this compression test any good?
I took a car to a local muffler shop to have compression and timing checked. I know all the guys that work there so they took care of me. Anyway, they had to advance the timing all the way and the car is running good, but not good enough. Now when they did the compression thest, here's what they came up with:
#1: 130
#2: 125
#3: 125
#4: 127
Thos are my rough estimates as the paper is in the car. But it was all within 5 psi and all between 120 and 130. Does that seem a bit low?
Old May 2, 2008 | 10:59 PM
NVR2LOW's Avatar
Default Re: Is this compression test any good? (Scrapin4DR)
That does seem awfully low
Old May 2, 2008 | 11:02 PM
NVR2LOW's Avatar
Default Re: Is this compression test any good? (NVR2LOW)
anything lower than 140 in a honda isnt really that good.
Old May 3, 2008 | 05:11 AM
Dogginator's Avatar
Daisy... Daisy...
Was then engine warm and the throttle wide open? Did you have the timing belt replaced recently? Improper cam timing could cause low compression.
Old May 3, 2008 | 09:40 AM
Kr0n1k's Avatar
What motor is it? That looks bad.
Old May 3, 2008 | 09:49 AM
Scrapin4DR's Avatar
Default Re: (Kr0n1k)
Timing belt was replaced recently, me and my buddy did it, and we had to tear it down a copule of times to get the timing right. So we got that, and it was still hesitating under 3k rpms so i took it to a buddy at a muffler shop, and they did the compression and advanced the timing. The car runs good, but still not quite right, and still a bit of heistation. I'm gonna ask him if the motor was hot or cold.
b18b1 motor.
Modified by Scrapin4DR at 11:05 AM 5/3/2008
Old May 3, 2008 | 10:25 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (Scrapin4DR)
sounds like the timing was still off
redo the timing and buy a compression tester (30$) at autozone etc
do the compression test yourself, if you dont know how there is a good write-up at http://www.c-speedracing.com
Old May 3, 2008 | 03:09 PM
Blahblah718293's Avatar
Default Re: (EARLdaSQUIRREL)
are you talking about valve timing, or ignition timing? ignition timing will not effect compression.
to be honest it could be worse, its most likely a valve timing issue, but it would be alot worse if it was like 180-180-50-170.
Old May 4, 2008 | 07:55 AM
lmike6453's Avatar
i believe the problem is whomever did the compression test sat in the car and held the gas pedal while cranking...
supposed to be a 2 man job with one actually holding the throttle body wide open while the other sits in the car and cranks, *WITH ECU FUSE AND BACKUP FUSE OUT OF ENGINE BAY FUSE BOX*
Old May 4, 2008 | 10:59 AM
Default Re: (lmike6453)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">i believe the problem is whomever did the compression test sat in the car and held the gas pedal while cranking...
supposed to be a 2 man job with one actually holding the throttle body wide open while the other sits in the car and cranks, *WITH ECU FUSE AND BACKUP FUSE OUT OF ENGINE BAY FUSE BOX*</TD></TR></TABLE>
i do compression tests by myself all the time, i unplug the distributor, have the car at operating temperature, and i go and plug in tester in cyl 1 then sit in the car with gas all the way down and crank 8 times per cylinder, works perfect for me everytime
Old May 5, 2008 | 02:57 PM
lmike6453's Avatar
instead of holding gas down have someone else hold the throttle body wide open...or do it yourself and pop on the remote start if you have one
Old May 5, 2008 | 03:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">instead of holding gas down have someone else hold the throttle body wide open...or do it yourself and pop on the remote start if you have one</TD></TR></TABLE>
what do you think holding the throttle wide open will do compared to holding it wide open with your foot on the gas??? haha
Old May 5, 2008 | 06:33 PM
lmike6453's Avatar
maybe you're throttle cable is loose or when you press the gas is doesn't hold the throttle body wide open...
stan xx
Aug 28, 2015 04:29 PM
MyWhiteEJ6
12
Nov 10, 2013 06:38 PM
Samuels
May 26, 2007 08:34 PM
RockLee`
Oct 29, 2006 03:43 PM
