compression test?
Old Apr 23, 2002 | 11:42 AM
spankaveli's Avatar
Default compression test?
my friend has a compression tester and since im burning oil we're gonna check it out tomorrow.
what should the numbers be across the board on my 94 Integra GSR motor?
also does anyone know the fomula to calculate static compressoin according to the psi reading on the gauge?
thanks
spanky
Old Apr 23, 2002 | 12:08 PM
GSRwBOOST's Avatar
Default Re: compression test? (spankaveli)
depends.. but post the readings.. make sure car is warm.
stock i think is around 220??
all numbers should be within 20 of each other.. reguardless of the numbers you get..
edit.. :: unless you get like 50 in each one.. LOL
i have 190 roughly in mine, but also have lower compression pistons...
dont worry about calculations.. just check it, post the numbers...
slightly lower numbers indicate worn rings, large drops indicate something more.. like pistons or rings are gone.. etc..
Old Apr 23, 2002 | 12:26 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: compression test? (GSRwBOOST)
a large drop could also be a bent valve, but you would probably know that by the way the car idles.
Old Apr 24, 2002 | 04:19 AM
digitalhav0c's Avatar
Default Re: compression test? (PatrickGSR94)
or a really loud. metal to metal noise. mine has a bent valve my first cylinder was about 60 points lower than all ther other one's.
ef9itb
Feb 6, 2011 06:21 AM
Hoodwinked
May 14, 2004 08:28 AM
greenli0n25
Jan 26, 2004 07:29 AM
EF8_SiR
Jul 20, 2003 10:24 PM
shamoo
Sep 25, 2002 02:53 PM
