Compression test
Old Feb 7, 2006 | 03:38 PM
batmang yO!
Guest
Posts: n/a
Default Compression test
According to c-speedracing.com when doing a compression test on your engine, you should see +/- 20psi accross all four cylinder. So I decided to do a compression test on my GSR, and the results I got were a bit different from what I expected...
#1 - 217psi
#2 - 230psi
#3 - 230psi
#4 - 240psi
(give or take 2 psi)
Now I realize im at just over +/- 20psi accross the board here, is this right?
Any opinions? or suggestions?
btw... its a 97 b18c1, bone stock (according to the previous owner anyways)
Old Feb 7, 2006 | 03:50 PM
94eg2sol's Avatar
cyl 1 looks a little off from the rest of em . . When you pressure tested did each cylinder shoot up to like 80 or 75 on 1st crank and jsut kept getin higher after every crank ? if so i wouldnt worry about it
Old Feb 7, 2006 | 03:54 PM
sc4dr's Avatar
Default Re: Compression test (Beavis)
I wouldnt be worried
Old Feb 7, 2006 | 04:01 PM
adseguy's Avatar
Default Re: Compression test (sc4dr)
Everything is fine
Old Feb 7, 2006 | 04:13 PM
batmang yO!
Guest
Posts: n/a
thanks for the input guys.
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
92vxjdm
Aug 15, 2008 05:05 AM
Uncle Ben's
Dec 8, 2007 12:21 PM
dreamreaperx
Dec 20, 2006 02:01 PM
VTC_CiViC
Oct 8, 2001 06:11 PM
