compression ratio?
Old Feb 11, 2004 | 11:59 AM
Si Integra's Avatar
Default compression ratio?
If I put 9:1 gsr pistons in my ls block, with ls spec rods and crank...what will my compression ratio do?
Do the pistons stay the same, or do they fluctuate in compression?
what can I expect?
Also, what rings do i use, will the rings be the same for the piston type and the 81.50 size?
Old Feb 11, 2004 | 12:53 PM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: compression ratio? (Si Integra)
Standard bore pistons are 81mm I believe, you should just use OEM GSR rings with your pistons, the ratio should be whatever the ratio is on the pistons unless you have head work.
Old Feb 11, 2004 | 02:29 PM
JDM_Risa's Avatar
Default Re: compression ratio? (JDMThoughts)
http://www.c-speedracing.com go to how to then go to compression calculator
pretty informative site
VVENOM800TT
Feb 17, 2011 02:48 PM
dc2_916
Sep 14, 2008 10:23 AM
Si Integra
Feb 11, 2004 02:11 PM
greengangsta
Mar 18, 2002 07:23 PM
