compression psi to ratio
Old Sep 26, 2005 | 09:50 AM
tegman85's Avatar
Default compression psi to ratio
can anyone give me a roundabout ratio for 210psi? thanks for any replies
Old Sep 26, 2005 | 10:08 AM
mmuller's Avatar
Mad Scientist
Default Re: compression psi to ratio (tegman85)
you cant really put a set # since compression(psi) numbers are variable; readings change with altitute, type of compression tester, cams, etc..
ef_si
Jul 25, 2013 02:09 PM
6E LUDE
Nov 10, 2005 05:38 AM
ITR.00-1282
Mar 30, 2003 09:04 AM
