compression numbers
Old Feb 4, 2005 | 07:28 PM
JDM_Spec's Avatar
Default compression numbers
today i did a compression test, when i pulled my new ngk iridium plugs out they were extremely black. only had them for 2 months. and my compression was 195, 190, 185, 180. but when i did it i forgot to remove the FI fuse. r these numbers good for a 94 GSR with 60000 miles ? and why is my plugs so black?
Old Feb 4, 2005 | 08:43 PM
CNSK's Avatar
Default Re: compression numbers (JDM_Spec)
94 with 60k miles ....as long as your number are +/- 10 from eachother you should be good....but it should be higher in the 200-220 range.....
flangemastermike
May 31, 2006 08:13 AM
1 2 NV
Jun 21, 2003 09:42 PM
wm5holla
Mar 23, 2003 03:39 PM
keys
May 29, 2002 06:49 PM
nugget8000
Aug 13, 2001 09:51 AM
