Compression number question
Old Aug 17, 2004 | 06:25 PM
VDoP-B18C1
Guest
Posts: n/a
Default Compression number question
Say you have a gsr with 10.1
i dont know what compression they yield but lets just say 240
now you take another engine, say a ls, put in some 10.1 CR pistons in there,
would it also yield 240?
is it the same for all engines?
Old Aug 18, 2004 | 04:28 AM
JimBlake's Avatar
Default Re: Compression number question (VDoP-B18C1)
Not the same. It depends on the cams, how much overlap & the valve timing.
Same pistons in another engine might not have the same CR, since it depends on the combustion chamber volume in the different head, & also the stroke. You might need different pistons to get the same CR.
Compression PRESSURE depends on valve timing, overlap, starter RPM, ring seal, & other stuff that doesn't affect CR.
Old Aug 18, 2004 | 05:13 AM
VDoP-B18C1
Guest
Posts: n/a
Default Re: Compression number question (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Not the same. It depends on the cams, how much overlap & the valve timing.
</TD></TR></TABLE>thanks
noracelimit
Mar 30, 2009 12:21 PM
1xfastxhatch
15
Feb 11, 2008 05:10 PM
94gsr18kid
10
Jan 25, 2005 05:35 PM
qcktegls
16
Nov 10, 2004 08:04 PM
