Compression
Old Aug 23, 2006 | 04:21 PM
GoldCoin's Avatar
Default Compression
I took my car to a mechanic cuz i coudnt figure out whats wrong. and he said its my compression. and i wanted to know how what they do and how much its gonna cost on avg. so that i know hes not trying to expletive me over.
Old Aug 23, 2006 | 05:14 PM
GoldCoin's Avatar
Default Re: Compression (DC TWOin IT)
bump it
Old Aug 23, 2006 | 05:17 PM
ac_attak's Avatar
Ask him what is causing the loss in compression. I guess that is what you are talking about
Old Aug 23, 2006 | 05:22 PM
Dogginator's Avatar
Daisy... Daisy...
Did they perform a compression check? If so, what were the numbers? Did you overrev recently?
Old Aug 23, 2006 | 05:30 PM
GoldCoin's Avatar
Default Re: Compression (Dogginator)
well i sent it in today . and hes gonna check it tomrrw. but yea . haha eversince i got my head built which was about 5 days ago ive been hitting redlines and i think on one or two occasions i overrevved it. but ill get a print out or something of the numbers . and post it . but what do they do to fix this problem and how much is it going to cost me?
off subject. this is the reason why my car isnt starting?
Old Aug 23, 2006 | 05:32 PM
Dogginator's Avatar
Daisy... Daisy...
Your valves may need to be adjusted as well. The only ways to really overrev is to misshift from say 3rd to 2nd at redline, which causes a mechanical overrev, or to install a chipped ECU that has a high (or no ) rev limiter. WHo installed the head?
Old Aug 23, 2006 | 05:36 PM
trick_db's Avatar
as long 4 cylinder is consistent, like it will tell you whats wrong with the motor, like leaking, and other ****. get a compression test, is not so hard, if you search there will be some link you can find that help you do your own compression test. gl
GoldCoin's Avatar
i sent it in to a performance shop and they did all of that. i have a chipped ecu at 8200 redline and i have been downshieft 3rd to 2nd and hitting 6ks in 2nd gear.
Old Aug 23, 2006 | 05:43 PM
trick_db's Avatar
no problem, 3rd to 2nd is fine, just wait til you get the test result back, btw where you locate? from san diego?
Old Aug 23, 2006 | 05:46 PM
GoldCoin's Avatar
Default Re: Compression (trick_db)
yea im from san diego . haha . have you seen me on the streets?
Old Aug 23, 2006 | 05:48 PM
trick_db's Avatar
nah, what car you drive? got pics? what part of diego, im from diego too.
Old Aug 23, 2006 | 05:49 PM
GoldCoin's Avatar
i will have pics when my car is out of the shop . hopefully tomrrw. but i dunno how long compression and all that stuff takes to fix. but yea im near mira mesa area up north.
Old Aug 23, 2006 | 05:52 PM
trick_db's Avatar
haha, i never go past mira mesa, well sometime, what kinda car you drive, you should go to the ikea meet this sat.. i'll will go there for the first time checking out the scenery
Old Aug 23, 2006 | 05:56 PM
GoldCoin's Avatar
ikea meet? my friend lives right across the street form there. haha . i didnt know they had a meet there.
i drive a 94 LS Fully Built Head Bottom Stock for now. Green color
but do you know what the procedure is to fix compreesion and how long it should take?
Old Aug 23, 2006 | 06:05 PM
GoldCoin's Avatar
help on expected time and procedure or compression?
bump
Old Aug 23, 2006 | 06:17 PM
trick_db's Avatar
depend what it is.
Old Aug 23, 2006 | 06:30 PM
Dartanian's Avatar
Am I missing something here? What is the problem?
If it doesn't have compression and it is head related, my money is on a bent valve. The head will have to be pulled and the valve replaced. Had the same thing happen to me. It wouldn't start, so I pulled the valve cover and one of cylinder 3's intake valves was stuck in the down position causing 0 compression.
Old Aug 23, 2006 | 06:35 PM
GoldCoin's Avatar
Default Re: Compression (Sleeper Style)
how much did that cost you?
Old Aug 23, 2006 | 06:40 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC TWOin IT &raquo;</TD></TR><TR><TD CLASS="quote">how much did that cost you?</TD></TR></TABLE>
Valve ~ 20
Headgasket ~ $80
12 pack of beer ~ $13
Labor ~ Priceless
Old Aug 23, 2006 | 06:42 PM
GoldCoin's Avatar
how much does anyone think a shop would charge for the head pull etc.?
Old Aug 23, 2006 | 07:02 PM
GoldCoin's Avatar
need input fast plz . pm me if you know around what price labor would be.
SantaAnaFerio
11
Dec 15, 2009 03:06 PM
zoom545
Nov 22, 2005 09:04 AM
Pandahatch
Aug 31, 2004 11:59 PM
020
Sep 30, 2002 07:52 PM
