Complicated wiper question!?
Hey guys, been a while since I posted here, but I got kind of a silly question. The wiper assembly on my 1995 LS has begun to fade, chip, and peel revealing what is I assume the shiny steel or aluminum below. I got some flat black weather resistant paint, now my question is: how do I remove the entire wiper assembly from the motor up? I need to do this for both the front windshield wipers and the hatch wiper. If this doesnt make sense, I can try and provide some pictures of what I'm talking about. To sum up: how do I remove the entire wiper arm, not just the blade holder?
Thanks,
Platoon918
Thanks,
Platoon918
the front ones have a bolt on each wiper that holds them on.
the back one has a bolt that holds on the wiper arm but it is under the thine plastic cover. be careful when prying it up. if its cold outside and you're using a screwdriver, it may break. But it is relatively easy to take off and once you do, the bolt will be visible.
[Modified by au-gsr, 1:59 PM 11/23/2002]
Thanks so much guys, I saw an articel about removinc the rear wiper. Looks like a neat cosmetic mod, that I will look into. Have any pictures of your car without the wiper? Thanks again.
Ok and ran into a problem, the back wiper. I got the plastic over off and the bolt, but now the wiper assembly wont come off. What do I do?
flip the spring up and then jiggle it a lil. i thought ine was stuck on there but after a good nudge it came rigt off. if its really stuck try the screwdriver thing again.
Takes a bit ofr workin back and forth.
swizz977
25
Dec 31, 2011 02:00 PM
