coilover/sleeves
Old Nov 27, 2005 | 03:53 PM
aaroboost's Avatar
Default coilover/sleeves
Alright i was wondering if there is a big differnce in using adjustable coilover sleeves on sport struts or just a full coilover setup. i realize the full system is pretty much always more expensive. is it worth the extera money?
Old Nov 29, 2005 | 08:24 AM
aaroboost's Avatar
Default Re: coilover/sleeves (aaro890)
bump...
Old Nov 29, 2005 | 09:36 AM
Seto-Initial-B's Avatar
i would have to say the full system coil overs would be a better choice. I went the cheap way and now i'm wishing i spent the extra 300-400 hundred more. heh
Old Nov 29, 2005 | 10:18 AM
PrinceAli132's Avatar
Getting good struts and coilover sleeves with the right spring rates will be just as good as most fullcoilover setups. Look into the koni yellows and ground control coilovers.
Ali
Modified by PrinceAli132 at 3:47 PM 11/29/2005
Old Nov 29, 2005 | 11:02 AM
dynamo's Avatar
Default Re: coilover/sleeves (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Look into the koni yellows and ground control coilovers. </TD></TR></TABLE>
Old Nov 29, 2005 | 02:47 PM
aaroboost's Avatar
Default Re: coilover/sleeves (dynamo)
alright for a DA at tirerack the koni struts run at 129 a piece plus 300 for the ground control goods. this is about 820 bucks. the skunk2 full coilovers run 750. any opinions?
thanks
Old Nov 29, 2005 | 02:56 PM
dynamo's Avatar
Personally, I found the Skunk2's to be unbearable when driving on the street, especially with my 120mi/day commute. GC and Koni's are a great street combo, and the KONI's stiffness can be adjusted if you are going to the track, so unless you're a full-time racer that should do fine.
Just my $0.02
Old Nov 29, 2005 | 09:08 PM
Try looking in the sponsor section.
Ali
Old Nov 29, 2005 | 09:41 PM
Danronian's Avatar
Try the sponsor marketplace. You'll find koni yellows for $420 a set shipped, super cheap for great struts. That's what I'm getting in the spring for sure, goodbye stock struts.
Old Dec 1, 2005 | 06:39 AM
aaroboost's Avatar
Default Re: (Danronian)
thanks guys. i probly wont get the skunk2 ones, since i will be driving daily. appreciate the advice
Old Dec 1, 2005 | 11:51 AM
IntegraCF21's Avatar
I have the Skunk2 sleeves with Koni reds and I have it on my a daily driver all year and I don't see anything wrong with it. I love the way they ride and handle. It's kind of bouncy, but that should be somewhat expected.
Old Dec 1, 2005 | 12:13 PM
kNOwLedGeDA9
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Getting good struts and coilover sleeves with the right spring rates will be just as good as most fullcoilover setups. Look into the koni yellows and ground control coilovers.
Ali
True statement. Listen to this guy. Koni yellows (GC specific) and GC custom rated sleeves is a race tested setup. Some of these new coilovers coming out are stuff made to sell to naive people who think they are getting a better suspension setup than shocks/springs for a couple hundred dollars more.
For example: Omni power and D2 coilovers. IMO the cheapest coilovers that you can get that are better than a goos spring/ adjustable shock setup are TEIN Super Streets.
Old Dec 1, 2005 | 08:32 PM
XkjeldorX's Avatar
so any kind of sleeve coilovers u get will be bouncy? i want to get coilovers but i dont want i bouncy ride. i want it kind of stiff.
Old Dec 1, 2005 | 08:35 PM
Default Re: (XkjeldorX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XkjeldorX &raquo;</TD></TR><TR><TD CLASS="quote">so any kind of sleeve coilovers u get will be bouncy? i want to get coilovers but i dont want i bouncy ride. i want it kind of stiff.</TD></TR></TABLE>
No, a crappy spring will yield a more bouncy ride. Having stiff struts (koni yellows) and a mildly stiff spring will ride harsh and will not be bouncy.
Ali
Old Dec 1, 2005 | 10:52 PM
dynamo's Avatar
Default Re: (PrinceAli132)
KONI's are adjustible - I have mine set at 1/2 of a turn (out of 2 full turns). You don't have to have them turned up all the way on your daily driver unless you enjoy the harsh ride. Mine are paired with GC coilovers, and my ride is perfect for the street - stiff enough in the corners, but not too bouncy on open road.
Old Dec 2, 2005 | 05:53 AM
aaroboost's Avatar
Default Re: (dynamo)
What about the megan racing coilover sleeves? these are cheap but are they uber crappy? anyone tried em out?
Old Dec 2, 2005 | 07:08 AM
Adam West's Avatar
Default Re: (aaro890)
I was wondering the same thing I just bought the omni- coilover sleeves........... I got ebay's world classs springs on there now.... havent drivin it yet but got a goo deal on the omni's with 448lbs in da front and 336 in the rear... all I need is a good set of shocks..
Old Dec 2, 2005 | 09:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaro890 &raquo;</TD></TR><TR><TD CLASS="quote">What about the megan racing coilover sleeves? these are cheap but are they uber crappy? anyone tried em out?</TD></TR></TABLE>
Don't put that crap on your car. If your going to spend money on your car, spend it wisely. Yes you might pay more, but its better to pay more now, then have to buy the same part twice and have to go through the aggrivation of installing and doing other ****, which will probably cost you more in the long run.
Ali
Modified by PrinceAli132 at 1:19 PM 12/2/2005
Old Dec 2, 2005 | 09:15 AM
dynamo's Avatar
Don't put that crap on your car. If your going to spend money on your car, spend it wisely. Yes you might pay more, but its better to pay more now, then have to buy the same part twice and have to go through the aggrivation of installing and other doing other ****, which will probably cost you more in the long run.
Ali</TD></TR></TABLE>
Agreed. Took me 5 suspension setups to figure out what I want and what works.
Old Dec 2, 2005 | 10:14 AM
aaroboost's Avatar
yeah thats what i figured. thanks for the help
2DoorBandit
Suspension & Brakes
10
Mar 5, 2006 12:39 PM
Rob.
Suspension & Brakes
16
Feb 11, 2006 06:13 PM
turbotime
Suspension & Brakes
19
May 16, 2005 07:58 AM
07
May 18, 2004 11:32 AM
rasta420
14
Dec 4, 2002 04:09 AM
