Coilover help / Adjusting
Old Sep 12, 2009 | 09:52 AM
Cripton805's Avatar
Default Coilover help / Adjusting
I have a 90 Integra with coilovers. I cant get my adjustments right on my coilovers. The car seems lower or higher on each sides. Any tips to get the car leveled? Thanks
Old Sep 12, 2009 | 10:16 AM
gsrvong's Avatar
Default Re: Coilover help / Adjusting
Make sure your car is on a flat, level road or driveway or parking lot. Adjust each coilover accordingly. For example, look at your car dead on in the front. If the passenger side is higher, lower just the passenger side to level it with the driver side. Or vice versa. Same goes for the rear. If all else fails, put stock springs back on lol.
Old Sep 12, 2009 | 10:19 AM
Duncman's Avatar
New User
count your threads on the coil. make sure you have the same amount...
Old Sep 12, 2009 | 02:58 PM
b16-ef-si's Avatar
if u have sleeves make sure that the sleeves are right side up on all sides..
i used my fingers to measure the clearance between the turning thingys lol
no fingers to 1 finger dumped then 2 is too low then 3 is just right haha
use a tape measurer to measure ride hight so that its even on both sides
Old Sep 13, 2009 | 08:28 AM
Cripton805's Avatar
Thanks I used a tape measure and it keeps off by 1 inch. I think youre right about the surface though. Its at an angle at the drive way
like this --> /
haha
Old Sep 13, 2009 | 08:31 AM
Cripton805's Avatar
One of my struts went out on the passenger side and its KYB and the others are skunk 2. Would this make a difference in height?
Old Sep 13, 2009 | 04:32 PM
b16-ef-si's Avatar
i believe that the skunk2 are abit stiffer so the ride height will be the same when u adjust it acordingly but the ride will be different...aka stiffer on the S2 side but softer and a bit bouncy on the KYB...i had some tokicos on my teg in front and some oem in bak and the bak was preety dam bouncy but the front stiff as a ****
Old Sep 14, 2009 | 08:50 PM
Cripton805's Avatar
thanks 4 the tips. Check out new pics on my profile if you like. jus posted 2dai
19josh91
14
Jun 4, 2013 08:10 AM
unknownally
Jun 20, 2010 08:31 AM
ComCool
Suspension & Brakes
Jun 7, 2006 10:13 AM
digitalspice
Nov 27, 2001 07:11 PM
