code67
Old Apr 13, 2006 | 07:05 AM
MenaceL.A.671's Avatar
Default code67
i have a 2000 gsr obd2b and im reading a code 67.. what should be the problem.. thanks....
Old Apr 13, 2006 | 07:07 AM
Lan's Avatar
Lan
Default Re: code67 (MenaceL.A.671)
https://honda-tech.com/zerothread?id=978933
Old Apr 13, 2006 | 08:23 AM
Default Re: code67 (Lan)
67 Catalyst low efficiency. (same as P0420)
Catalyst System Efficiency Below Threshold
yup what the hell does that mean???
Old Apr 13, 2006 | 08:25 AM
so i need to change it out or get a aftermarket cat.?
Old Apr 13, 2006 | 08:28 AM
Lan's Avatar
Lan
Pull your cat off. It could be the 02 but.... Take the cat off, hold it up to the sun and see if you can see through it. If you can't - you need a new one. You can use a pipe to hollow it out, factory cats are $$.
Old Apr 14, 2006 | 03:22 AM
wow we even pop the cat.... so pretty much yeah no more screen!
but the check engine light still on..
Old Apr 15, 2006 | 04:11 AM
M2S~Juan's Avatar
burn it...
Old Apr 15, 2006 | 04:20 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MenaceL.A.671 &raquo;</TD></TR><TR><TD CLASS="quote">wow we even pop the cat.... so pretty much yeah no more screen!
but the check engine light still on..</TD></TR></TABLE>
What don't you understand?
The CEL is on because you do not have a functioning cat.
99d-series
11
Oct 29, 2008 11:40 AM
crazyguy
17
Nov 9, 2007 07:00 AM
Jesterian
11
Jul 6, 2006 05:19 PM
Boring
Jan 1, 2005 04:31 PM
brisk
Apr 7, 2004 01:56 PM
