code 72 gsr
Old Oct 13, 2005 | 02:15 PM
sikcrx80's Avatar
Default code 72 gsr
well i am working on my bros car.
his car is givving me code 72 sounds like it is misfiring or maybe somthing wrong with the cat maybe cloged.
i am getting a code 72 and im not to sure what it is.
ive checked cap and rotor and all the spark pugs and #2 was all gunked up cleaned them all..
im not to sure where to go from here..
any info would be great
Old Oct 13, 2005 | 03:29 PM
sikcrx80's Avatar
anyone...
Dogginator's Avatar
Daisy... Daisy...
Default Re: code 72 gsr (sikcrx80)
Cylinder number 2 is misfiring. Could be bent valves, bad plug wires, clogged fuel injector, etc.
KaleGSR's Avatar
Since you know the code why dont you search the internet, ive ran accross a few places that will give you the info on the code
Old Oct 13, 2005 | 03:31 PM
sikcrx80's Avatar
bent valves eh..
well when i took spark plug out it was all covered in crap. how do u tell if it a bent valve?
Dogginator's Avatar
Daisy... Daisy...
Default Re: (sikcrx80)
Compression check.
Old Oct 13, 2005 | 04:44 PM
debogsr's Avatar
Default Re: (Dogginator)
how does the car run?
Has there been a change in gas octane recently? Sometimes that will do it.
Old Oct 13, 2005 | 04:52 PM
sikcrx80's Avatar
well the car runs good but at idle to like 3gs u can here a miss in the exhaust. there is a little shake comming from engine that i can feel when car is running.
when i do a comp test it will show a very low pressure...right
i think its going to be a valve prob. as he told me he was going through the gears and when he got to the top if fourth at 8gs it made a noise either after his shift or just as he got there.
Old Oct 13, 2005 | 05:56 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikcrx80 &raquo;</TD></TR><TR><TD CLASS="quote">when i do a comp test it will show a very low pressure...right</TD></TR></TABLE>
You want consistent numbers for all four cylinders. A GSR will typically read about 200psig. However, that value depends on the guage, motor, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikcrx80 &raquo;</TD></TR><TR><TD CLASS="quote">i think its going to be a valve prob. as he told me he was going through the gears and when he got to the top if fourth at 8gs it made a noise either after his shift or just as he got there.</TD></TR></TABLE>
It could be a clogged injector that is running lean at higher RPM.
Old Oct 14, 2005 | 01:48 PM
sikcrx80's Avatar
well i found out what it is..
there is 30psi in cylinder #2
so i guess he likes putting valves in it i guess.
Old Oct 14, 2005 | 01:55 PM
Dogginator's Avatar
Daisy... Daisy...
30psi... I would guess that the piston has a hole in it.
EL Vap133
37
May 3, 2024 01:13 PM
LH-93
Sep 7, 2008 04:28 PM
Crasian
Dec 30, 2005 11:42 AM
AntonioH
Aug 1, 2005 09:52 AM
reVVin
Mar 31, 2002 07:03 PM
