Code 6
Old Jan 11, 2009 | 04:39 PM
Ricextacy's Avatar
Default Code 6
the only check engine light code i got is Code 6
The:
ECT - Water temperature Sensor
do i have to replace the sensor? or is it cuz the fan isnt hooked up?
anybody ever have this code, if so what did u do?
Old Jan 12, 2009 | 10:49 AM
Ricextacy's Avatar
Default Re: Code 6
bump
Old Jan 12, 2009 | 11:01 AM
mouab18c1's Avatar
Default Re: Code 6
try hooking the fan up to see if the CEL will go away..if not then you just need to replace the sensor
Old Sep 5, 2009 | 03:18 PM
BEATurBOYS's Avatar
Default Re: Code 6
Location of sensor please.
Is it the one on the thermostat housing?
Old Jan 6, 2010 | 09:14 PM
EFLS89's Avatar
Default Re: Code 6
I have the same cel. Try the fan 1st. If not, then check the wiring, and it depends on what motor you have. I have a obd-0 LS. I would really appreciate it if someone can post a picture or diagram of the color of the wires for the sensor, seeing to as how the person before me did a wire tuck and for some reason left the water temp sensor out the picture.
Old Jan 6, 2010 | 09:29 PM
EFLS89's Avatar
Default Re: Code 6
jdmjackson
Jan 30, 2013 04:31 PM
coffin on wheels
Feb 22, 2007 11:22 AM
Mastuh4
Nov 3, 2004 09:49 AM
Nerv2g
Jul 29, 2003 08:19 AM
