Code 41 question
Old Oct 24, 2002 | 10:31 AM
Fez's Avatar
Fez
Default Code 41 question
Code 41
Primary Oxygen Sensor - Heater
circuit malfunction
What do I check for?
Do i just replace the o2 sensor?
CODE VEHICLE DEFINITION
1 86-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2 86-87 Civic
Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 86-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor
4 88-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
5 86-98 Civic*
97-98 CRV
85-98 Prelude
94+ Integra MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping
* not 94-95
6 86-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7 86-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor
8 86-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
9 86-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
* invalid code for throttle body injection Hondas
** invalid code for V6 engines
10 86-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
12 86-98 Civic
85-98 Prelude
94+ Integra EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
* invalid code for non-equipped EGR valve vehicles
13 86-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor
14 88-98 Civic
97-98 CRV
88-98 Prelude
94+ Integra IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
15 88-95 Civic
88-95 Prelude
94+ Integra Ignition Output Signal missing or defective ignition output signal
16 88-95 Civic
88-85 Prelude
94+ Integra Fuel Injector System defective circuit or unplugged / defective fuel injector
17 88-98 Civic
97-98 CRV
88-98 Prelude
94+ Integra VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
19 88-95 Civic
94+ Integra Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 88-98 Civic
97-98 CRV
92-98 Prelude
94+ Integra Electrical Load Detector defective circuit or unplugged / defective sensor
21 92-95 Civic
93-95 Prelude
94+ Integra VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
22 92-98 Civic
93-98 Prelude
94+ Integra VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
23 96-98 Civic
92-98 Prelude
94+ Integra KS (Knock Sensor) defective circuit or unplugged / defective sensor
30 92-98 Prelude
94+ Integra Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor
* invalid code for 1996
31 92-95 Prelude Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor
41 92-98 Civic
97-98 CRV
90-98 Prelude
94+ Integra Primary Oxygen Sensor - Heater circuit malfunction
43 92-95 Civic
90-95 Prelude
94+ Integra Fuel Supply System defective or malfunctioning fuel supply system
45 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra System Too Lean or Too Rich malfunction in the fuel monitoring systems
48 92-98 Civic
94+ Integra LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor
54 96-98 Civic
97-98 CRV
94+ Integra CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
61 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
63 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
65 96-98 Civic
97-98 CRV96-98 Prelude
94+ Integra Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra Automatic Transmission malfunction with the automatic transmission controls
71 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80 96-98 Civic
96-98 Prelude
94+ Integra Exhaust Gas Recirculation insufficient flow detected
86 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 96-98 Civic
97-98 Prelude
94+ Integra Evaporative Emission Control System leak detected in the fuel tank area
91 96-98 Civic
97-98 Prelude
94+ Integra Fuel Tank Pressure Sensor low input
92 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra Evaporative Emission Control System insufficient purge flow
Old Oct 24, 2002 | 07:32 PM
b_edson's Avatar
Default Re: Code 41 question (GSRjunky)
Had that on my car, check the wiring on the 02 sensor. Mine was just disconnected.
Old Oct 25, 2002 | 05:28 AM
Fez's Avatar
Fez
Default Re: Code 41 question (b_edson)
I hope thats all it is, i took my header off and got the code afterwards.
Old Oct 25, 2002 | 06:45 AM
speedymon's Avatar
The wire probably came loose. Must be a defect in Honda's wiring harnesses cause mine came loose to. It's a common problem.
Old Oct 25, 2002 | 09:36 AM
Fez's Avatar
Fez
Default Re: Code 41 question (speedymon)
Did yours also come loose at the o2 sensor?
Old Oct 25, 2002 | 04:14 PM
speedymon's Avatar
At the plastic socket where the two sets of wires snap together. The pin was further down in the socket and wasn't making contact with it's mate.
efyou999
May 24, 2012 12:21 AM
sh!ft
May 13, 2009 01:18 PM
sharky8513
12
Feb 5, 2005 08:25 AM
NAB16AEK
Jan 19, 2004 06:19 PM
EVILD16BSTD
May 7, 2003 10:00 AM
