Code 3 after b20vtec swap
Old Aug 21, 2013 | 09:23 AM
DaBigHert's Avatar
Default Code 3 after b20vtec swap
I need some help. I swapped a b20vtec into my 91 integra (it previously had an obd0 b16). I also upgraded to obd1 at the same time using a jumper harness and and ecu with a base tune that I purchased from Phearable. I am now getting a code 3(map sensor) and the car is running very rich. I'm still using the original firewall mounted map sensor, it was fine before the swap. I also have an issue with the tps. If I set it properly I get a code 7(tps sensor). If I set it out of range, the code goes away. Any ideas?
EGk3nrock
Apr 27, 2007 06:59 AM
ViXoN Hatch94
Apr 17, 2006 07:11 PM
Flyingchopstick
Jul 14, 2005 11:24 AM
gsr2envy
Nov 7, 2004 03:32 PM
foesicks
Jun 4, 2003 09:47 AM
