clutch problems
Old Mar 26, 2009 | 09:47 AM
imroadk1ll's Avatar
Default clutch problems
so ive been noticing that every time i start the car now days and press down the clutch i hear a squeak, how i get rid of that. also wen i press all the way down on the clutch and turn the key all the way it doesnt turn the car on or the engine has a hard time starting. so now wen i start the car i dont press the clutch all the way down and its all good wen i turn the key.
Old Mar 26, 2009 | 10:17 AM
1992db2's Avatar
Default Re: clutch problems
the squeaky noise is probably your throw-out bearring and the rest of the problems your getting, sounds like you just need a new clutch. Is it cable or hydro? if its cable, try adjusting the clutch. I dont think it will do a whole lot but its woth a try
Old Mar 26, 2009 | 06:15 PM
imroadk1ll's Avatar
how do i know if its cable or hydro?
Old Mar 26, 2009 | 09:12 PM
1992db2's Avatar
what car and year?
Old Mar 26, 2009 | 11:41 PM
imroadk1ll's Avatar
95 gsr
Old Mar 27, 2009 | 10:28 AM
1992db2's Avatar
its hydro, theres no adjustment on those. changing your clutch would be your best bet
Old Mar 27, 2009 | 02:35 PM
capn's Avatar
The squeak could just be the return spring on the pedal, put a little grease on it. The starting problem may be the clutch safety switch. Make sure that it is working properly.
Old Mar 27, 2009 | 05:56 PM
imroadk1ll's Avatar
ill do that if the bottom quote does not work
does anyone have any pics of the spring? where is this clutch safety switch?
Chi925
Transmission & Drivetrain
Jan 31, 2012 05:55 PM
Jeff
Jan 8, 2006 05:18 PM
Jonathan_ED3
Aug 14, 2004 10:25 AM
91HATCH
Jan 9, 2003 12:06 PM
