Clutch Issues... Please help!
Old Jan 26, 2011 | 02:36 PM
Hondakid4eva's Avatar
Default Clutch Issues... Please help!
I dropped the trans out of my car. At first I thought it was the cable, but realized it was not snapped. So now that i have the trans out of the car im not too sure what to do from here. The lever on the outside of the trans feels very light to me. Any thoughts on what to look for?
I bought the car already modified/rigged up :/ Everything will be cleaned up before being put back together.
lever down
lever up
and the can of worms.
Old Jan 26, 2011 | 05:46 PM
Default Re: Clutch Issues... Please help!
bump. id like to get some parts tomorrow to get back on the road asap!
thanks in advance
Old Jan 26, 2011 | 08:37 PM
sik96teg's Avatar
cant tell much from just those pix also u didnt say what the issue was that you were having with the car prior to pulling the tranny. I can tell the rear main sell is blown. If the pressure plate and disc have never been replaced that could be causing issues since the car is 20 years old. So i would get a clutch kit, replacement clutch cable, rear main seal and have the flywheel resurfaced but thats just what i would do with having the tranny out.
Old Jan 27, 2011 | 02:44 AM
Blackpin93's Avatar
INTECHNICOLOR
What's the problem exactly? That's pretty damn dirty, either that's original or something bad happened, I'd guess. Replace the clutch disk, pressure plate, throw out bearing, and pilot bearing, if you can. Resurface flywheel, as said.
khmerJimmy
Sep 7, 2012 07:31 PM
zeroairskter
Feb 3, 2011 09:03 PM
ThA IntegrA HI
May 20, 2008 11:16 AM
EF'n
Jun 30, 2002 06:00 PM
