Clutch install question??
Old Nov 25, 2002 | 07:15 AM
GSR-REX's Avatar
New User
Default Clutch install question??
I did a search and really didn't find what I was looking for....
I'm getting ready to get my new clutch installed and all of the shops I call keep telling me that they want to replace the rear main seal while they're in the transmission.
Is this totally necessary? Should I go ahead and get it done?
Thanks in advance.
Old Nov 25, 2002 | 07:19 AM
RSvtec's Avatar
Default Re: Clutch install question?? (GSR-REX)
that really depends on you, the mileage on the motor and the money.
Old Nov 25, 2002 | 07:23 AM
GSR-REX's Avatar
New User
Default Re: Clutch install question?? (RSvtec)
Well...The car has 60,000miles on it, but its a 94. I'm getting the clutch replaced because its beginning to slip a bit and smell like its burning after long drives.
A couple of the shops said that the labor will be the same and that the part isn't that expensive. I'll probably just go ahead and get it done. No sense Half-Assing it.
Anybody know where I can get one cheap?
Thanks
Old Nov 25, 2002 | 09:32 AM
hitop's Avatar
Out of curiousity, how much are u paying for the clutch job? Thanx for any info on that.
Old Nov 25, 2002 | 09:57 AM
Trac226's Avatar
Default Re: Clutch install question?? (hitop)
Yup, save yourself some leaks and replace it.
Old Nov 25, 2002 | 10:29 AM
Quik Chris's Avatar
Hmmm, rear mains on B-series don't really leak that often. Sounds like something unnecessary to me that they're going to get more money from you. It's like going to the doctor to have your toncils out and having him suggest a face lift while he's in there. 60k is NOT high miles at all, I'm sure your rear-main is just fine. Screw those guys. Don't cave to the sales tactic.
Old Nov 25, 2002 | 10:50 AM
GSR-REX's Avatar
New User
The quotes I have gotten so far are between $320 and $570!!! The $320 was for just installation of the clutch. If the flywheel needs replacing, thenthat will be an extra $50. If the rear main seal needs replacing, that'll be an extra $40!
It looks like I'm not going to get away without paying about $400 to get this thing put in!!
Clutches are expensive
Old Nov 25, 2002 | 10:52 AM
GSR-REX's Avatar
New User
Default Re: Clutch install question?? (Trac226)
I probably will get it replaced...one of the shops said that he won't charge me any extra labor and if I buy one and bring it in to him, that would save him from charging me for one.
I guess I'll call Autozone and see how much they are.
Old Nov 25, 2002 | 10:55 AM
GSR-REX's Avatar
New User
Just called Autozone...Rear Main Seal is only $9.93...I'm going to go ahead and do it. For $10 bux....its worth it.
collin-eg2
Mar 30, 2012 12:26 AM
90civic-ZC
Mar 3, 2012 02:32 PM
SXEtony
Apr 27, 2007 04:03 AM
Sohc Driver
Jul 18, 2004 06:54 PM
integrakilla
Apr 28, 2004 12:47 PM
