Clutch help
Old Jun 13, 2008 | 10:01 AM
sibious's Avatar
New User
Default Clutch help
I'am having trouble with my clutch pedal engaging. I filled it up with fluid to the max, but it stil wont let me put it in gear. There is no resistance in the pedal till its the floor, and most time wont even engage then. Im new to hondas and was wondering if anyone had any ideas.
Thanks in advance.
Old Jun 13, 2008 | 03:37 PM
HONDAx415xHONDA's Avatar
Default Re: Clutch help (sibious)
sounds like it could be three things...the clutch master cylinder is bad and/or the clutch slave cylinder is bad. and the obvious clutch could be bad. check the slave and master cylinders first for any leaks, if none found most likely the clutch.
Old Jun 13, 2008 | 03:53 PM
JuggsxCOmanDO's Avatar
hmm could be slave
b16a4
Nov 18, 2006 11:04 AM
Greenery18
Jul 8, 2005 04:22 PM
DriveSideWays
Aug 27, 2004 05:06 PM
FLCivic
Jun 30, 2004 03:48 PM
VTC_CiViC
Nov 17, 2003 08:10 AM
