Cluster prob with 94 LS
my gauges on my cluster wouldn't illuminate at all even though bulbs and fuses were fine.
i used a voltage tester to test the wires and it came back that the one for illumination was rather weak but not dead.
how do you replace it and where does the wire run 2?
u need to get a wiring diagram and pick through it till you can figure it out but i belive if you wanted to do a quick fix you could run a wire to one of the heaglight wires but im not sure if the cluster is run off relays or not best of luck man
ive searched for wiring diagrams wit no luck on here or team integra..........i was thinking on wiring it up to another power but not sure which yet.....thanks and bump if anyone has a wiring diagram
yz125rider21
Nov 13, 2005 10:48 PM
Proper
Oct 21, 2002 12:06 AM
