Cluster Light? What to do
Old May 18, 2008 | 07:26 PM
kelviiv's Avatar
Default Cluster Light? What to do
Hello
so i've search on TI and on HT
it seems like my fuse went out. everything worked including the turn signals / srs/ etc, but the cluster would not light up and the climate control would not light up. so i went and checked the fuse and sure enough it was blown. i replaced it and the fuse would blow within a second of putting it in and yes I AM using the correct amp fuse.
anyone know what to do now ?
Old May 18, 2008 | 09:29 PM
dc2_97teg's Avatar
Default Re: Cluster Light? What to do (kelviiv)
Well i did have that problem before. What i did was upgrade the fuse by other 5 amps and then i just dimmed my cluster lights. And that solved my problem. Hopefully that works for you too man
Old May 18, 2008 | 09:31 PM
kelviiv's Avatar
i tried bro :[
no luck it just burns it out right away
Old May 18, 2008 | 10:22 PM
dc2_97teg's Avatar
Default Re: (kelviiv)
Possibly you have a short or a bad ground in your car. Best bet is to trace the wires. Unless someone else here in HT have another idea. Best of luck man.
bresk8r87
Oct 17, 2007 07:47 AM
rodimus
Aug 3, 2005 06:57 PM
Slvr_CRX
10
Jul 12, 2005 12:06 PM
Streetdreams022
Jan 8, 2005 08:20 AM
