Clogged Cat? Maybe?
Old Apr 17, 2009 | 08:47 AM
dump3deg6's Avatar
Default Clogged Cat? Maybe?
I bought a full stock exhaust off a guy, and i took the cat off, and tried to look through it. I could BEARLY see through it, like BEARLY!
Anyway, when i put it on, very little pressure was coming out the muffler. It ran fine, but the cat started to smoke and smell a lil funny. Never once got glowing red like others i see.
Today the car ran perfect, vtec pulled good, all that. Then it started to act weird, like seems like its taking forever for it to rev. It will hit vtec and all that but doesnt pull at all like it was before. And it seems kinda jerky when taking off. No CEL's, good oil level, ect.
Symptoms of a clogged cat?
Thanks,
Old Apr 17, 2009 | 08:53 AM
felixjr18's Avatar
Default Re: Clogged Cat? Maybe?
the cat is supose to have a small hole so that it can filter... did you do anything ti the cat like poke a bigger hole in it ect?
Old Apr 17, 2009 | 08:55 AM
dump3deg6's Avatar
no sir. Havent done that.
Havent touched anything. I can see the honeycomb inside, but cant see through it that well.
Old Apr 17, 2009 | 09:02 AM
SuzukaBlueAP2's Avatar
It's barely.
If you hold the cat up to some light you should be able to see a small area where the light shines through. By your description, barely seeing through it indicates that you could, in fact, see through it; just very little. And that sounds normal.
Old Apr 17, 2009 | 09:04 AM
felixjr18's Avatar
also did your check engine light come on after the install check your o2 sensor and make sure it wasnt damagedc some how in the process
dump3deg6's Avatar
Yeah sorry for my spelling.. VERY long morning already
Im not sure why its running the way it is though. Its blowing decently out the exhaust, just taking a min to rev up under load.
The ECU im running has deleted the o2 sensor, so thats out of the subject.
Old Apr 17, 2009 | 09:16 AM
dump3deg6's Avatar
Seems sluggish..
Im most likely going to pull out the cat and give it a few good wackings to empty out the guts.
Free is always better
Old Apr 18, 2009 | 02:36 PM
dump3deg6's Avatar
Anyone else?
Drove it today, seems worse
Old Apr 18, 2009 | 10:14 PM
ARdb8's Avatar
theres two ways i would confirm a "clogged" cat. 1) disconnect the cat from the rest of the exhaust system then run it.. any difference? 2) if you have an infra red temp gun, at normal operating temp, the cat should be about 100-150*F (pre cat) cooler than post cat. make sense?
Old Apr 18, 2009 | 10:19 PM
dump3deg6's Avatar
Yeah, I had planned on pulling the cat off, and checking it out.
Run it open header to see if it changes anything on low end power.
As soon as it cranks up, I would know if it was the problem or not.
It runs HORRIBLE! Absolutly NO power, and feels as if the car is dragging.. More pedal I give it, the slower it seems to go.
Cat isnt glowing red, but the car is filled with a stinch.
Old Apr 18, 2009 | 10:27 PM
ARdb8's Avatar
hmm.. try looking into fuel delivery (fuel filter, pressure...). if ok, check ignition (fouled/wet plugs...)
Old Apr 18, 2009 | 10:45 PM
sp00ledbseries's Avatar
Im gonna have to go with the cat
Old Apr 18, 2009 | 10:50 PM
dump3deg6's Avatar
Yeah. It cranks fine. It Slowly started to get worse.
When I crank the car up, Very little pressure comes out the exhaust.
It seems like it sputters from like 1k-2k RPM... I got to rev it to about 3500 to take off without bogging.
Im preeeeety sure that's the problem. It never did this until I put on this exhaust
Old Apr 19, 2009 | 09:31 AM
ARdb8's Avatar
keep in mind that catalytic converters are actually "doing work" when fully warmed up. when cold, its useless. typical honda cats run up to 350-400*F.
Old Apr 19, 2009 | 09:38 PM
dump3deg6's Avatar
Well got a update..
Took the cat off, and looked super clean.. Cranked the car up and still sputtered.
Went into further diagnosis and started pulling the injector clips off the injectors. #1 and #2 cylinders hardly changed when I unplugged them. Pull the injectors out and the Injector Filters were FULL of gunk. .
Clean the filters, replaced, cranked up and purr'd like a kitten.
Problem solved!
Thanks for all input guys!
Old Apr 20, 2009 | 08:18 AM
ARdb8's Avatar
Good job!
mortificationrock
12
Jan 28, 2010 12:09 PM
project91crxsi
37
Aug 16, 2009 07:35 AM
CBR600OnTop
Apr 16, 2003 05:19 AM
JoshRambo
Oct 1, 2001 02:31 PM
Halo
Jul 14, 2001 08:50 AM
