Clock on dashboard stuck at time.
Old May 11, 2012 | 10:43 AM
Da_1991's Avatar
Default Clock on dashboard stuck at time.
As it says in the title, **** stuck at 7:06 lol. I am guessing I just need to disconnect the battery terminals and reset it. Anyone experience this?
Old May 11, 2012 | 02:17 PM
Jeffaj20's Avatar
Default Re: Clock on dashboard stuck at time.
Or you can just pop it out and unplug it. I used a butter knife gently on the sides to walk it out. I tried stereo remove tools but the tabs wouldn't fit. lol
Old May 11, 2012 | 07:00 PM
civic ef's Avatar
Yea mine is stuck @ 1:00 maybe jz a blown fuse jz check I changed some fuses not long ago for the lighted in side and it worked but I think my fuses blow again I will check tomorrow and let u know if it works again
Old May 14, 2012 | 05:38 PM
Da_1991's Avatar
Cool. Not really a problem but I'll probably check the fuses.
Old May 14, 2012 | 05:43 PM
Double Agent's Avatar
If the time is lit but not changing it could be a bad unit, a fuse would cause the clock to go out completely, not stop. Try disconnecting it (or the battery), maybe it'll reset. Otherwise I'd say you need a new clock.
Old May 17, 2012 | 10:12 AM
Da_1991's Avatar
Ah I see. Thanks for the info.
HotImportNightHonda
14
Oct 10, 2024 12:34 PM
rhd_ef8
12
Apr 29, 2007 11:27 AM
Mychal71
Sep 10, 2006 02:01 PM
bennjamin@ozhonda.com
Sep 4, 2006 05:20 AM
FastHatch90
Apr 3, 2006 07:47 PM
