???? CLIMATE CONTROL ????
I have a 95 integra SE and i just got done building it up and im doing all the finishing touches to get it ready to register. The thing is though, is that the air doesnt work so when its cold at night and my windows need to defrost i cant. To take off hte climate control and see if everything is plugged in i was wondering if i have to take off any of hte plast center consoles???
I have the same problem in my 95 dc, but the problem with mines is that the climate control cable was cut and thats the reason why it doesn't work. Maybe you might want to try that, I'm still looking for the cable for mines I might have to just go to the dealer and order it which would suck because they are going to charge the hell out of me.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoppa »</TD></TR><TR><TD CLASS="quote">I have a 95 integra SE and i just got done building it up and im doing all the finishing touches to get it ready to register. The thing is though, is that the air doesnt work so when its cold at night and my windows need to defrost i cant. To take off hte climate control and see if everything is plugged in i was wondering if i have to take off any of hte plast center consoles???</TD></TR></TABLE>
Yeah bro, your gonna have to take of the plastic "vent" piece. There are two screws behind the hazard and rear demister button. Before you start just let me tell you that its a real bitch to get the climate control out. I did the JDM itr amber conversion today and it was annoying as f*ck trying to take it out
BTW inlanddc2 I have a spare climate control if you are needing one, just missing the two slider *****
yeah its hard to take out the climate control wen u never done it before, lastnight it took me 3 hours and i still cant figure it out, so i had my friend send me an integra service manual from the dealer had like 1500 pages but tells you how to take every part step by step, well after i got hold of the manual only took me 25 min to take out the climate control, first you have to take out the hazard and defroze, den take out the 2 screw, and take out ur radio, den look for the air mix cable to follow it, it end on the left just below the glove box, den unclip the cable and pull it out of the metal wire, den use a small but long screw drive to go under the climate control to pop the green and white wire hareness out, den the whole piece should come right out. GOOD LUCK
civics4lyfe
Jun 2, 2008 10:30 AM
