clicking noise when accelerating
Old Oct 24, 2010 | 05:53 PM
gotrust's Avatar
Icon6 clicking noise when accelerating
ok ik there is some other threads that have a similar question on them, but the clicking noise i have is when i accelerate very softly i dont hear it, but when its a normal accelerate or more it makes up to 6 clicks then shift to 2nd and get the same thing for every gear. i only hear in in gears 3-5 when you give it a lot of gas, but every time in 1-2 sometimes 3rd. But when im just driving at a constant in any gear i dont hear it, also my motor moves a lot when i let off the gas in 1-2 does this mean i need new mounts they dont look bad..
its a 95 gsr 5spd btw
here's whats new (some of the stuff wouldnt affect it ik just sayin what i got)
20,000miles ago
pistons
rings
rod bearings
timing belt
crank bearings
spark plug wires
gaskets oil seals
engine mounts
drive shaft boot
oil/filter
10,000 miles ago
clutch plate
preasure plate
release bearing
1,000 miles ago
front left drive shaft
thx
Old Oct 25, 2010 | 05:42 AM
fcm's Avatar
fcm
Old Fart
Default Re: clicking noise when accelerating
Is clicking there only if car is moving or can you hear it if you just rev the engine? 94
Old Oct 25, 2010 | 06:39 AM
gotrust's Avatar
Post Re: clicking noise when accelerating
its only when i move if i just rev it dont make it
Old Oct 25, 2010 | 07:15 AM
senser1080's Avatar
I think it's a bad axle, wheel bearing, or cv joint.
Old Oct 25, 2010 | 10:46 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^, most likely a C/V joint. 94
Old Oct 25, 2010 | 05:38 PM
gotrust's Avatar
ok thaks a lot guys ill look into it, is that hard to fix? DIY
Old Sep 27, 2011 | 03:38 PM
gotrust's Avatar
After all this time found out it was loose subframe bolts..
Old Sep 27, 2011 | 08:15 PM
Jimmy's Avatar
Global Moderator
Wow.. those definitely need to be tight
Did you check the axles out anyways?
Old Sep 27, 2011 | 08:26 PM
NemesisCBR's Avatar
^ simple inspection of the boots should tell you. They start clicking after they tear open and loose grease.
88Hatchy
Apr 29, 2009 03:46 PM
ludesrv
Aug 30, 2008 09:36 AM
chueflee
Nov 13, 2007 10:36 AM
ProjectDarkBlack
Apr 27, 2007 11:39 AM
BudMan
Aug 11, 2004 04:58 AM
