clean engine bay
Old Apr 27, 2010 | 05:16 PM
Oknoe.'s Avatar
Default clean engine bay
im planning on spraying degreaser all over my engine bay, rinsing it
then spraying armor all or some other sort of cleaner for a nice shine
...is there anything i need to cover up or avoid spraying?
like battery, distributor, alternator, belts, etc.
or do i juss go in there with my pressure hose and do work????
Old Apr 27, 2010 | 05:22 PM
MD426's Avatar
Default Re: clean engine bay
Cover your electrical stuff and make sure you don't pool water anywhere it would be likely to seep into the engine. Also try to avoid getting water under the valve cover gasket, water in your oil would not be very good, so no close up pressure washing on the valve cover.
Old Apr 27, 2010 | 05:47 PM
dntnedvtec's Avatar
Yes...
Old Apr 27, 2010 | 05:53 PM
dntnedvtec's Avatar
when you dgrease it though, be sure to rinse quickly or else your going to spot your engine..
Old Apr 27, 2010 | 07:53 PM
WDG_729_ITR's Avatar
As mentioned above, cover up your electrical stuff. You also want to cover up your intake, and any other openings you see that you wouldn't want to get water in. I wouldn't spray any armor all or anything afterwards...degreasing it, maybe scrubbing some spots with a scouring pad/sponge, and then rinsing it will do just fine. I would just do the valve cover separately after you degrease it. Perhaps you could even repaint it to make it look really nice.
Old Apr 27, 2010 | 07:54 PM
Could you provide some before and after pictures?
mynameizstitch
Jul 3, 2009 09:24 PM
mynameizstitch
Jul 3, 2009 04:15 PM
polishedturd
Mar 6, 2008 11:45 AM
Euro98ITR
Nov 5, 2003 04:34 PM
GTI 20v
Acura TL, RL & ZDX
Aug 1, 2003 11:47 AM
