checking fuel pump
Old Jan 15, 2009 | 10:17 AM
oilspot's Avatar
Default checking fuel pump
Working on getting a 91 integra started. First off I had to re solder the main fuel relay because it wasn't working. Thats working now. Now when I turn the key on I don't hear any noise indicating that the fuel pump is priming. So I have a few questions about this.....
I've read that to check for fuel that you can disconnect the line from the fuel rail.... If I do this I'm afraid that I'm going to spray fuel everywhere, and catch the neighborhood on fire.
another question... I pulled the back seat bottom out. The wire that goes to the pump should be yellow and black. I was expecting a larger single wire. The only wires I see are the bundle that plug into the regulator there on the top of the tank. Is the wire I'm looking to test the small one in that bundle?
Old Jan 15, 2009 | 10:38 AM
MD426's Avatar
Default Re: checking fuel pump
Easiest way to check for fuel would be to crank it. If it runs then your fine, if it starts then dies then the pump isn't working.
The power wire your looking for is a yellow/black wire in the bundle. There is also a yellow one, make sure you don't modify that one. To check for voltage just unplug the connector and use a volt meter, positive end on the yellow/black post, negative on the black or green wire.
Old Jan 15, 2009 | 01:25 PM
Perfectionist's Avatar
Keep in mind the main relay only sends power to the pump for a second or two when the key is first turned to the 'run' position. The relay is re-energized when the ECU senses the engine is turning.
Old Jan 15, 2009 | 01:37 PM
oilspot's Avatar
I don't think the pump it working. I'm using a test light and probing into the top of the connections on the fuel pump relay. The black and yellow wire (that goes to the pump) stays hot even after the second click. But not a sound from the pump.
quartermilerun
20
Jul 8, 2017 09:24 AM
civic28
Mar 26, 2014 04:18 PM
jthrasher1
Dec 11, 2010 12:45 PM
Charlie Moua
May 13, 2010 10:29 AM
