Check engine light help!!!!
Old Dec 16, 2008 | 01:44 PM
bsampson's Avatar
Default Check engine light help!!!!
ok i went to an import shop near me and got it scanned and its code P0116 (Engine Coolant Temperature Circuit Range/Performance Problem) Possible causes? What exactly this is? and Should i fix it?
Old Dec 16, 2008 | 03:46 PM
LS stretch's Avatar
bad sensor or you could have a wiring issue
Old Dec 16, 2008 | 03:50 PM
neardon's Avatar
I'm a Jackass
http://www.google.com/search?q=p0116+code just a quick resource.
Old Dec 16, 2008 | 03:54 PM
H9Omega's Avatar
Like stated above, check some of your wiring, it may have gotten deteriorated or even have a bad/loose ground. After that is said and done, try checking around the marketplace, or your local dealership for the temperature sensor and replace it, it's a real simple fix.
cooltool
Aug 15, 2011 07:56 AM
Tru2Less
Dec 31, 2007 07:17 AM
ShinotakuX
Dec 17, 2007 10:04 PM
civicex_88005
Jun 21, 2005 02:17 PM
tegon-gsr
Jul 25, 2003 08:26 AM
