Check engine light coming on constantly??
Old Jul 29, 2003 | 08:22 PM
gsrboy18's Avatar
Default Check engine light coming on constantly??
Hey, just wanted to know if anyone has had this happen to them. I've got a 98 GSR and I recently have been throwing a check engine code 73, which is a random misfire. I thought that the problem was just my spark plugs and distributor, so I replaced them both and I am still getting the code to come up. The wierd thing is that it comes up for a while and then it goes away. When it does come on and stay on, sometimes it starts to flash and not stop until i turn off the car. The motors got 57000 miles on it and I am at a loss here, can anyone help. Any insights would be much appreciated.
Old Jul 29, 2003 | 08:29 PM
venomgsr95's Avatar
did you ask the acura dealer?
Old Jul 29, 2003 | 11:53 PM
gumbybum's Avatar
Default Re: Check engine light coming on constantly?? (gsrboy18)
not sure at all but check your fuses and stuff like that... if it is running bad have a shop run a diagnostic on it. good luck man
Old Jul 31, 2003 | 06:57 PM
3vilMonkey!'s Avatar
some cars automatically do that, they come on when it is scheduled for matinence. hold the milage button down while its running and turn the car off, power it back on and it might go away...or try holding it while it's off and hold it till u start it up...it worked on my dad's accord
Old Aug 1, 2003 | 01:17 AM
.xcalibur.'s Avatar
Default Re: Check engine light coming on constantly?? (3vilMonkey!)
Does the code show up when you jump the service connector. You might just need to reset the ECU and that should clear the code. If the CEL comes on then try trouble shooting it with the 98+ helms.
Old Aug 1, 2003 | 06:00 AM
redlinegsr's Avatar
Default Re: Check engine light coming on constantly?? (.xcalibur.)
Did you check your plug wires? Plugs gapped correctly?
AudioFunk
Jul 29, 2013 11:02 AM
leochilo
May 26, 2010 08:15 AM
blaze.1
Sep 24, 2009 11:04 AM
Ed 341
Mar 8, 2006 02:45 PM
Leo
Apr 8, 2004 06:06 PM
