check engine light code 45 system running too lean or rich. help!
Old Nov 5, 2004 | 05:52 PM
HONDA RR's Avatar
Default check engine light code 45 system running too lean or rich. help!
i have a 99 gsr which has a check engine code of 45. MY car puts out a lot of black smoke and idles very low at times. i changed my o2 sensor; the idle air control. After changing those it ran ok for a while and started doing the same thing. Is there anything i need to change like the intake manifold?
Old Nov 5, 2004 | 06:06 PM
smart monkey's Avatar
Default Re: check engine light code 45 system running too lean or rich. help! (MITSUBA)
you should check the fuel pressure and also the tune up parts. what mods do you have? any check engine lights?
Old Nov 6, 2004 | 04:39 PM
HONDA RR's Avatar
Default Re: check engine light code 45 system running too lean or rich. help! (smart monkey)
i don't have any mods the only check engine i get is a code 45 which is either the system running too rich or too lean.
Old Nov 6, 2004 | 10:31 PM
boosted k20's Avatar
black smoke = rich motor. u probably have a bad O2 sensor
Old Nov 6, 2004 | 10:34 PM
Seedc2's Avatar
Default Re: check engine light code 45 system running too lean or rich. help! (boosted k20)
whats the remedy to running rich? tip of my exhaust is black
Old Nov 7, 2004 | 09:06 AM
loud_whispers's Avatar
Default Re: check engine light code 45 system running too lean or rich. help! (sim shadeee)
Ok,
Low idle, black smoke.. your running rich.
1st step.. check your FUEL PRESSURE.
Take it to a local shop, have them run a fuel pressure test on the car.
If it's high, probably your FPR or the fuel return pipe.
If the pressure is low, could be the fuel pump, feed pipe..could even be a fuel filter..
When's the last time your fuel filter was changed?
If absolutely none of that has done anything to fix the problem...
you'd have to resort elsewhere.. Maybe the MAP sensor or Purge valve.
you'll need a vacuum pump to test the purge valve.. it SHOULD hold vacuum.if not, replace it..
if none of this has worked at all..
replace the injectors..
Old Nov 7, 2004 | 09:12 AM
Default Re: check engine light code 45 system running too lean or rich. help! (loud_whispers)
still have the fuel pressure checked.
but i would replace the fuel filter since it is the cheapest and easiest if it hasnt been done in a while.
not changing out your fuel filter every so many miles contaminates the fuel supply system and causes problems like this where it could be a number of related problems.
treat your car right!
MAP sensor... very true. check it out. We had a 3-bar map sensor on one of our turbo cars. the sensor had a cut in one of the wires. This resulted in the computer dumping a whole shitload of fuel into the motor. we rewired it and the car ran great.
DawgC2
Mar 10, 2012 12:11 PM
B20inDCinLBC
Oct 10, 2008 10:44 PM
alispoon
Oct 18, 2005 07:08 AM
95hatchfire
Jan 12, 2005 10:52 AM
2000CX
Aug 14, 2003 05:15 PM
