check engine light back on
Old Oct 29, 2006 | 10:54 AM
coronadrinker's Avatar
Default check engine light back on
my check engine light came back on after 4 days, code 1 and 15 again. when i hooked up the universal o2 sensor(bosch) i hooked Gray to green, was that right? What do i do, i put in new spark plugs but still code 15, could it be that i need a new distributor? car runs fine.... so lost, need help!!! thanks
Old Oct 29, 2006 | 11:01 AM
SoTexDC2's Avatar
Default Re: check engine light back on (coronadrinker)
Distributor cap & rotor, does your car have 2 o2 sensors? did you replace the right one?
Fat Chick Magnet's Avatar
If your car is obd1 then the distributor is code #9. *cylinder sensor*
Old Oct 29, 2006 | 11:10 AM
Default Re: (dc2rtek)
I'll try cap and rotor, and suggestions on brand? will all the codes read the same if i have a p28 in my integra?
Old Oct 29, 2006 | 11:13 AM
SoTexDC2's Avatar
Default Re: (coronadrinker)
I would go with OEM, but might set you back a bit more. Not sure on the codes, Im using a P72 - obd1.
Old Oct 29, 2006 | 11:23 AM
Default Re: (SoTexDC2)
what about the o2 why the f@#k is that still coming on
Old Oct 29, 2006 | 01:23 PM
SoTexDC2's Avatar
What year is the car? OBD1 only recogonizes a single O2 sensor. If the car has 2 of them, you might have wired the wrong one up.
Old Oct 29, 2006 | 03:23 PM
who said i have 2? it only have 1. (not being a dick) ohh and it wasn't the cap and rotor, but hey at least i have new ones now, the rotor looked F'ed up n e ways
has anybody used the bosch universal o2 sensor?
Old Oct 30, 2006 | 09:09 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coronadrinker &raquo;</TD></TR><TR><TD CLASS="quote">has anybody used the bosch universal o2 sensor?</TD></TR></TABLE>
Worked fine for me, just follow the instructions on the wiring and you should be fine. Maybe its not the O2 sensor being faulty but a high/low reading due to your half-*** tuned P28?
Old Oct 31, 2006 | 05:56 PM
Default Re: (95 integra)
who said my p28 was half ***? and why wouldnt that have popped up right after being tuned, not 4 months later. if you think my **** is half *** you can talk to chris from whitfield, hes on HT
NiKKa NiKKy
Aug 6, 2009 10:14 AM
ALLMOTOR CRX
Apr 23, 2007 02:19 PM
96typeR
Dec 19, 2006 01:59 PM
sayiansean00
Oct 25, 2006 06:46 AM
SloCrxDx91
Aug 24, 2006 05:51 PM
