Check Engine Light...>_<
Old Mar 5, 2004 | 08:51 AM
Senbonzakura's Avatar
Default Check Engine Light...>_<
Alright after installing my skunk2 intake manifold for 2 week already. When i pushed it i felt good yeah of course. But then everytime i hit like 100mph the lights comes on. When i turn off the car and turn it on again the light is gone. I have no clue to what its about. Maybe pressure or something loose?
Old Mar 5, 2004 | 09:08 AM
stasi's Avatar
Default Re: Check Engine Light...>_< (Kyo Kusanagi)
Any idea what code(s) it's throwing?
Old Mar 5, 2004 | 09:09 AM
Default Re: Check Engine Light...>_< (stasi)
Haven't tried the code yet. Don't know how...&gt;_&lt;
Old Mar 5, 2004 | 09:32 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyo Kusanagi &raquo;</TD></TR><TR><TD CLASS="quote">Alright after installing my skunk2 intake manifold for 2 week already. When i pushed it i felt good yeah of course. But then everytime i hit like 100mph the lights comes on. When i turn off the car and turn it on again the light is gone. I have no clue to what its about. Maybe pressure or something loose?</TD></TR></TABLE>
What year is the car ? If it is 96-01 the OBD plug is under the dash on the passenger side of the car. Above the kick panel.
Old Mar 5, 2004 | 09:38 AM
stasi's Avatar
The plug is located under the dash on the passenger side, it's a green
plug. Put a paperclip in and it should flash. You're going to need to count
the length and number of flashes.
A long flash indicates tens and a short flash indicates ones, so one long flash will mean code 10 and one fast flash shows code 1.
For example: Flaaaaaash Flaaaaaash Flash = code 21
Flaaaaaash Flash Flash = code 12
Flash Flash Flash = code 3
(copy and pasted from a saved site)
Old Mar 5, 2004 | 09:55 AM
kNOwLedGeDA9
Guest
Posts: n/a
I think you mis-plugged one of your vacuum lines. I had this problem once and the light only went on over 7,000 RPM. it also went off when i turned the car off.
Old Mar 5, 2004 | 11:06 AM
Default Re: Check Engine Light...>_< (ScreaminTeg)
year is 94
1.8L_allmotormilitia
Jun 6, 2007 10:07 PM
Type X
Honda Civic (2006 - 2015)
64
Jan 11, 2007 08:11 AM
vtecvlow
Mar 28, 2005 11:26 AM
Senbonzakura
Dec 8, 2004 11:01 PM
kboy01gsr
Nov 14, 2003 03:09 AM
