check engine light
Old Aug 26, 2006 | 12:09 PM
Nautica_97gsr's Avatar
Default check engine light
i have a 97 teggy and my check engine light is on..i checked the emissions and the code p0303 came up. i changed my plugs and wires, checked injectors and changed o2 sensor and light is still on...anyone help???
Old Aug 26, 2006 | 01:56 PM
Fat Chick Magnet's Avatar
my check engine light is also on. it threw me code #9 which is cylinder sensor. i have no clue what that is, but i got use to the light being on.
Old Aug 26, 2006 | 01:58 PM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: (dc2rtek)
Lol. Be like homer simpson and put some black electrical tape over the CEL, that was hilarious. Awwwwwww expletive it.
Old Jul 2, 2009 | 09:28 AM
backyardinc's Avatar
Default Re: check engine light
Bump I have same code and need help also....
Old Feb 15, 2010 | 03:04 PM
FlatBlkEk's Avatar
Your P0303 is cylinder 3 misfire detected code. Now lets go over your diagnosis and see how you got to where you are now.
Did you erase the code after you replaced those parts?
Did you check to see if your getting spark from that particular cylinder wire(3) yes/no is it weak?
Did you perform a compression check to see if you have a burnt exhaust valve?
How did you check your injectors?
What brand did you go with on plugs and wires ?
Code 9 cyl position sensor(ckp) is a sensor inside your distributor that provides the computer with position for timing . Basically you need a new distributor or if your savy and have lots of parts, swap guts with another dizzy you have laying around like i would do : ).
importdude2000
Jul 17, 2004 12:53 PM
TyPe-R6
Jun 18, 2003 03:41 AM
PM-Performance
Nov 30, 2001 10:53 AM
