check engine codes
Old Mar 27, 2006 | 11:08 AM
fayaz925's Avatar
Default check engine codes
my 94 civic coupe has a 94 integra gsr swap. with a P28 chipped ecu. i am running a apexi vtec controller and the harness accidently was broke loose by my brothers foot. i reconnected it back on. doesnt turn on, check engine light is on, code 21 and code 22. vtec solenoid valve and vtec pressure valve. what could be the cause?"
Old Mar 27, 2006 | 11:16 AM
DC2 Mang's Avatar
Default Re: check engine codes (fayaz925)
the Vtec controller cuts cuts into the wire harness, if the vtec controller is not working then it is interfering with the signal to the vtec solenoid which is causing your car to spit a CEL
if the vtec controller is broken then i would remove it and hook ECU wires back up in the stock form and you should not have any more CEL codes popping up
GSRHATCH619
12
Apr 2, 2008 03:48 PM
Pr0ject93hb
Sep 14, 2007 09:50 AM
Mach69
Dec 23, 2005 01:26 PM
DohctorVtec
Jul 5, 2005 01:35 PM
Metrocity2
Apr 27, 2005 02:03 AM
