Center Console......
Oh boy let me tell you, getting that climate control out is a real pain. I did it awhile back to replace all the bulbs. You have to remove the front and rear sections of the center console, then remove the radio. All this is done in order to remove the wire harness clips that go up to the climate control, so you will have enough slack to pull it out. After you get the radio out, then you have to pry out the emerg. flasher switch and rear defroster switch in order to access the screws holding the center trim in place. Then get under the passenger side dash and remove the air mix control cable from the heater core. At this point the center trim/center air vents/climate control should all come out as a single unit. You should be able to find more detailed instructions on http://www.team-integra.net
remove the hazard light switch and the rear de-fogger switch, in behind then are 2 screws, remove them, pull off the ***** on all the slider controls, reach in from the passenger side and remove the wire that attachs to the heater control and pull the unit out.
Edit..oh yeah..forgot to mention to remove the stereo/ashtray/drinks holder and the centre console surrounding the gear shifter too....
[Modified by mugenracer, 5:05 PM 3/25/2003]
Tippyman
10
Jul 30, 2006 09:09 PM
GReddy SI
Jul 31, 2003 09:33 PM
