cel codes???? how to find them
Old Jul 12, 2003 | 11:51 PM
Visionist's Avatar
Default cel codes???? how to find them
where do you find the codes to know which one is flashing??
Old Jul 12, 2003 | 11:54 PM
xteg95's Avatar
Default Re: cel codes???? how to find them (jdmfantasy)
did you want to know how to check which CEL is going off, or what the code means. look on http://www.team-integra.net , they have a lising of CEL codes i believe.
Old Jul 12, 2003 | 11:57 PM
xteg95's Avatar
Default Re: cel codes???? how to find them (xteg01)
http://www.team-integra.net/se...ID=34
Old Jul 13, 2003 | 12:44 AM
Visionist's Avatar
where do you check at???
Old Jul 13, 2003 | 09:12 AM
Rory Breaker's Avatar
If youre OBD1, there is a little blue connector under the glovebox. Take a paperclip, bend it and connect the two sides. Turn your car on with the connection in place and the CEL light will flash your corresponding code.
Old Jul 13, 2003 | 09:46 AM
threatcon13's Avatar
New User
Default Re: cel codes???? how to find them (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">If youre OBD1, there is a little blue connector under the glovebox. Take a paperclip, bend it and connect the two sides. Turn your car on with the connection in place and the CEL light will flash your corresponding code.</TD></TR></TABLE> same for obd2
Old Jul 13, 2003 | 09:57 AM
Default Re: cel codes???? how to find them (Threatcon13)
Really? Ive never checked the code on an OBD2 car...you can check it the same way?
Old Jul 13, 2003 | 10:53 AM
nsxtasy's Avatar
H-T Order of Merit
Here's how to find the codes. Look in your service manual, in the fuel section. (I don't know why they put it in the fuels section, but that's where they put it.) You should see a heading called Troubleshooting and a section under it called Self-Diagnostic Procedures. It tells you how to pull the codes (by jumping the connector as mentioned above), identifies what each one represents, and tells you where to find a procedure for what to do for any given code.
If you don't have a service manual, and you want to work on your own car, you need to get one. It's worth every penny. You can buy one here.
music462
Apr 10, 2008 05:37 AM
crazyguy
Aug 21, 2007 10:01 AM
Kiniku Chunks!!!
Aug 28, 2006 07:37 PM
colombian linx
Mar 15, 2004 11:09 AM
BlkGSR
Jun 18, 2003 07:11 PM
