cel code 9 96 integra gsr
Old May 9, 2010 | 10:37 AM
tuckinrim's Avatar
Default cel code 9 96 integra gsr
OK my friends here's the issue getting a code 9 cell which is cyp sensor. Here's what I have tried so far. Ohmed sensor and wiring tried different Ecu and different sensor to no avail. Everything ohm's normal. Am I missing something?
Old May 9, 2010 | 06:33 PM
tuckinrim's Avatar
Default Re: cel code 9 96 integra gsr
Ttt
Old May 10, 2010 | 12:03 AM
SpeedjunkieDB1's Avatar
Check your cam gears take off the valve cover and check if they are inthe same position one of them is off that's why its throwing the cel light check your cams.
Old May 10, 2010 | 02:58 PM
trifenix's Avatar
you need to replace your distributor. Is it OEM or aftermarket? then set the timing.
chrisquin23
Aug 6, 2010 02:01 AM
pinoyboy204
13
Jun 22, 2006 02:31 PM
athoughts
12
Jul 3, 2005 10:16 AM
B00ST2nR
Sep 16, 2002 05:06 PM
Hard2Find
Aug 7, 2002 07:31 PM
